How to change the MU icon permanent
hi at all
how the subject says:
i want to change the icon of the MU's in addiction to an attribute (6 several) permanent
i already tried it with
@.BildNr := ....;
but this seems to be local and only for this object.
9 REPLIES 9
Re: How to change the MU icon permanent
You access only one MU with @; so you change the icon only for this object. If you want to change the icon for all MUs of a class, then you need to adress the class and change the icon there. Plant Simulation changes by default the icons depend on the state of the MUs. If you don't want this behavior, you need to deactivate the use of the state icons in the icon editor.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
it's the same MU but my MU's have an attribute (Prod) which could be (6, 007-003, 007-000,...)
and the method should change the symbol of the MU's in addiction to this attribute
So i created 6 different icons (0 .. 5) for one MU
is
do
 if @.Prod = "6" or @.Prod = "007-003" then
  @.BildNr := 3;
 elseif @.Prod = "7" or @.Prod = "007-000" then
  @.BildNr := 0;
 elseif @.Prod = "007-001" then
  @.BildNr := 4;
 elseif @.Prod = "007-002" then
  @.BildNr := 5;
 elseif @.Prod = "007-006" then
  @.BildNr := 2;
 end;
end;
it should work, if you deactivane the vector grahics and the state icons
What is the problem?
Steffen Bangsow
web: www.bangsow.eu
What are the state icons?
The problem is that the icons are changing back to the starting icon when they are moving to the next object.
Plant Simulation changes between icons depend of the state of the MU. If the MU is waiting, Plant Simulation changes to the icon with the name "waiting", default is "operational".
So you can solve your problem in two ways: copy your icon in the icons waiting and operational or deactivate this behavior, icon editor in V.11
V12..
Steffen Bangsow
web: www.bangsow.eu
i couldn't solve the problem so far
i posted my version below
the method is called "Symbol" and it will be activated at the sensor on the FS_1
could you maybe have a look at it?
thank you very much!
Your method symbol is not triggered by the sensorcontrol (instead steuerung_fs1).
Steffen Bangsow
web: www.bangsow.eu
Is it not?
because it is like in the image below
what I need to change?
your model version_1 has only 2 sensors...
You need to deactivate the state icons in the icon editor for the bramme in the class library.
Steffen Bangsow
web: www.bangsow.eu
