How to change the procTime distribution type
Hi
I would like to change the procTime of a Transferstation from e.g. Const 1:00 to Uniform 2:00, 4:00 using simtalk.
Normal I would just type?.proctime := 120;
But what to type when I also want to change the distribution. When I press F8 I get something like this: 2:00.0000 [Uniform: 2:00, 4:00]
Can anyone help, please?
3 REPLIES 3
Re: How to change the procTime distribution type
SingleProc.ProcTime.setParam("Uniform", 120, 240);
Thanks, super simpel. It is not so easy to find in the help file.
This answer saved me a lot of time, I struggled to find the solution elsewhere. Thanks!
