How to collect results?
How to  evaluate utilization statistics of the line?
What is average work in process in the system? Minimum, maximum & average.
Please help
Re: How to collect results?
for record the WIP you can use the inheritance of the MUs. The class knows the number of MUs in the model
<MU>.numChildren; you can use a TimeSequence to record the WIP:
value:
.MUs.EngineB.numChildren+
.MUs.EngineA.numChildren+
.MUs.EngineC.numChildren+
.MUs.EngineD.numChildren
interval: e.g. one hour
Then you can use a end-sim method to calculate the min,max and mean value. All this functions provides the TimeSequence e.g.
You need to delete the contents of the timeSequence in a init-method at the start of an experiment:
timeSequence.delete;
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Hey Steffen,
Could you please explain me a bit more about the time Sequence part.
the timeSequence is an Information Flow object which can record values .
with the recorded values during simulation  you can run the statistics at the end of the simulation
