How to configure simulation time in EventController
Builder
Builder
I need to make my simulation model run from 8:00-16:00 everyday, and for 365 days. How can be configure this in EventController?
3 REPLIES 3
Re: How to configure simulation time in EventController
the 365 days you can set in the eventcontroller --> end
to restrict the time per day you could use a shiftCalendar for the source (source blocking=false)
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Builder
Builder
Could you provide more details of ShiftCalendar? Havenot used it yet.
Thanks.
drag a ShiftCalendar from the folder resources into your frame, than drag the shiftCalendar on the Source --> will be inserted in Controls- ShiftCalendar
- open the ShiftCalendar, switch off the inheritance of the table
In your case you can delete the second row, set the start and end of shift-1 and delete the pauses.
Then the source will produce only parts during the working hours
Steffen Bangsow
web: www.bangsow.eu
