How to count thoughput
I have rwo sources in my model . Source1 start from 00:00 to 02:00 . Source 2 start from 2:00 to 4:00.
I want to know how much entity comes from source1 and source2.
I have set entity1 and entity2 at class library and construct a method at Drain>control>entrance.
The MU selection of source1  is constant and MU is .MUS.entity1 but it doesnt work.
if @.name="entity1" then
Throughput1:=Throughput1+1
elseif @.name="entity2" then
Throughput2:=Throughput2+1
end;
Re: How to count thoughput
Have you tried reading the attribute "StatNumOut" for each Source?
Source1.StatNumOut
Source2.StatNumOut
They will give you the number of MUs that have exited the source.
Please find the attached images to activate Display Panel. Where you can see how much entities produced by the source without Programming.
Thanks & Best Regards,
Abhilash Sridhar.
Abhilash Sridhar
Mercedes Benz R&D India, Daimler AG
