How to create and call a function with several arguments ?
Hi ,everyone!
As is shown  in the attachment, I create a method whose name is “getmin”,which passing several arguments, then I call it by  another method. However, it always reminders something wrong with the ”getmin” method. I need you great help , Thank you!
Re: How to create and call a function with several arguments ?
you need to define the data type of the return value ( -> dataType)
param  number1:integer,number2:integer
->integer
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Hi, steffen_B!
it works ,thanks for you answer.Althoughit is not an easy thing for me to grasp the syntax of simtalk2.0,I still insist studying it. I'll turn to expert like you for help when i am confussed.
Thanks this forums for disscussion!
