How to create mus per some rules
In my model, I want to create mu per some rule, namely everytimes create ten mus, and   I need create five times(manely fifty mus  in all), and the  interval between every times per "uniform",how can i do it,thank you very much
Re: How to create mus per some rules
this you can do with the standard-settings of the source:
- set your interval (uniform distributed)
- insert a tableFile into your frame
- MU-selection sequence cyclical  --> activate create as batch --> select your TableFile
- insert one row in the tablefile with your MU and the quantity of 10
- add an exit control (rear) to the source to lock the exit of the source after 50 parts:
if ?.statNumOut=50 then
 ?.exitLocked:=true
end
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
here an example
Steffen Bangsow
web: www.bangsow.eu
