How to create your own objects in UserObjects
Hello everyone!
I'm wondering how to create your own object in 'UserObjects'? So you don't need to change proctime etc. all the time.
Thanks and regards
Oa
5 REPLIES 5
Re: How to create your own objects in UserObjects
Either duplicate or derive the desired
class object (select and press right mouse button)
and then change the attributes
of the newly created user object.
Thanks for the answer!
When duplicate or darive I got my copy of that object in 'MaterialFlow' folder and not 'UserObject'. If a duplicate the object Station I get Staion1 in the folder 'MaterialFlow'.
How to do for to change the atribute location?
/Oa
Press SHIFT, then drag-drop the class-object to the new folder.
You can also directly derive/duplicate to a specific folder-location, by pressing CTRL+SHIFT while drag-dropping a class-object to a folder to derive it (or only CTRL to duplicate it).
___________________________________________________________
Alex Dilg, Consultant at SimPlan AG (www.SimPlan.de)
This post was good and/or helpful to you? Please provide some Kudos, thank you!
Now I made it work. Thanks for all help!
@Ollean
From v14.2 onwards, the newly created
objects are placed in the "UserObjects" folder.
