How to deal with the onexitcontrol?
Hello ,everyone
I have a problem, I will describe it in detail.As shown in the following picture with marks:
Firstly,the part goes to "L0" from source,As long as the "L0" has parts(L0.nummu>0), the part will move to "m1"  preferentially.
Secondly, the" entity1" goes to "PB" from source2,when the "L0" has no parts and the "m1" is empty (or not ocuppied). the part will move to "m1" from "PB"  .
However, the model cannot run like that above.What should I do ?
Looking forward to your suggestions!
Thank U!
Re: How to deal with the onexitcontrol?
since the exitControl is (normally) only called once, you need to wait for the condition to move the part e.g.
--wait for your condition
waituntil L0.occupied=false or M1.occupied=false
--move
if L0.occupied=false then
   @.move(L0)
else
  @.move(M1)
end
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Hi,Steffen_B
Thanks for your directions!
 the model can run smoothly as what I expect.
Give my best regards to you!
