How to deal with the "error" pop-up when start the model?
Hello,everyone
I created a model 2 days ago and it went smoothly.However ,today,when i run it again, an "error" pops up.As is shown in the following picture,I cannot understand it so that i won't dealt with it.
I also post the model in the attachment,you can refer to it.
Looking forward to your directions!
Best regards to you!
Betreff: How to deal with the "error" pop-up when start the model?
Hey MarkLee,
you forgot to post the model.
Alex
In addition: you should at least consider updating to the latest patch of 13.1, but actually it would be better to update to Plant 14.0. Whatever problem your model has, maybe it is already fixed in the latest patches.
Hi,sir
Here is the model!
Hi MarkLee,
with Plant 14 the model does not crash (with 13.1 it does crash, and already while opening). Instead you get this message:
This is because you have set materialflow objects as controls, but you can only use methods here:
Hope this helps, regards
Alex
Hi,sir
if I update v13.1 to 14.0, where can I download the latest patches?
Assuming you have your WebKey at hand:
https://download.industrysoftware.automation.siemens.com/
Hi,AlexD
Thank you ,this topic is finished.
Give my best regards to you!
