How to find out what position in the transporter a mu is stored
Builder
Builder
How to find out what position in the transporter a mu is stored?
Example:
Transporter capacity = 12
Transporter.xDim = 12
Transporter.Ydim = 1
if There´s a mu stored in the position 6 (transporter.contentslist[6,1]), How to identify it through a method?
is there any attribute to catch this information?
Re: How to find out what position in the transporter a mu is stored
to locate a MU on the transporter you can use: <mu>.getStoragePlace(x,y)
to access the MU on a place:
<transporter>.pe(x,y).cont
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Builder
Builder
in the plant sim v.12 I did not find the function "mu.getStoragePlace(x,y)", is it available from v.13?
in the case, the mu is placed in some unknown position of the transporter. I need to identify the x,y position where it´s stored (through method).
getStoragePlace is new in version 13.1
you could try a search algorithm e.g.
local i,k,x,y:integer;
for i:=1 to transporter.xDim loop
for k:=1 to transporter.yDim loop
if transporter.pe(i,k).cont /= void and transporter.pe(i,k).cont = yourMU then
x:=i;
y:=k;
exitLoop 2;
end;
next;
next;
Steffen Bangsow
web: www.bangsow.eu
Builder
Builder
Good!!!
Thanks a lot!
