How to hide sensor grahpic in 3D
In 3D viewer, the sensor graphic is always appeared in the scene, can anyone tell me how to hide it?
Re: How to hide sensor grahpic in 3D
In Version 13, you can set the attribute _3D.ShowSensors of the respective object to false in order to hide the sensors. In that version, you will have to set that for every single object in which you want to hide the sensors.
In later versions, this attribute also supports inheritance (albeit that its inheritance will be cut initially if you load a model of version 13) and it is accessible in the 3D properties dialog.
Hello PeterKomarek, Thanks very much!
