How to import the plant layout drawed by Ato CAD into plant simulation?
 Hello, everyone!
 When I analog production lines of plant layout drawed by CAD,which consists of large objects(different machines ,conveyors,AGV ,robots,etc.) with different size,i find it very difficult to edit all the objects because the workload is huge and  incredible.Is there a simple way to importing the layout into simulation models?
It's much better if you share a video .
Looking forward to your directions !
Any hepl is great apprecited!
3 REPLIES 3
Re: How to import the plant layout drawed by Ato CAD into plant simulation?
Hi MarkLee,
You can drag AutoCAD (*.dwg) or MicroStation (*.dgn) files into your frame and use the CAD layout as a background image.
Ralf
Hi,Ralf!
  Thank you!
Thank You!
