How to know the number of collisions between transporters each other
Dear Plant Simulation Expert,
I have a question on the number of collisions between transporters.
For instance, there are many inter-sections on the lanes, in case of that, could i check the number of collisions between transporters each other ?
as I know, there is a method 'collided' to just show true or not(i.e collided or not).
But, if collided, then,  I want to know the number of collisions.
Thanks in advance.
BR,
Beagle.
Re: How to know the number of collisions between transporters each other
you can create your own statistical value for this case:
insert into the transporter in the class library a user defined attribute (e.g. statNumCollided: integer).
Add an observer for collided to the transporter in the class library;
param Attribut: string, oldValue: any
if oldValue = false then
	self.~.statnumCollided:=
	self.~.statNumCollided+1
end
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Dear Mr.Steffen Bangsow,
Thank you for your kind & fast feedback !
BR,
Beagle.
