How to make a Template ?
Builder
Builder
Is there any way to make a customised template and use it for all the work. for using the changed icons and other attributes I think saving all these changes in the template makes the work easy.
Anyone?
Betreff: How to make a Template ?
Hello K_parashar,
you can dublicate all basic objects and group them together in a sub folder. This sub folder you can save as a library. All objects within the library can be modified in any way.
Everytime you start a new project, you can load your specific library as a template for your simulation model.
You also can create new versions of your library and update your simulation models with the new versions. To do so, enter the directory path of your library in File->Preferences->Libraries directories. This enables Plant simulation to check for new libraries of your own.
GG
GG
Builder
Builder
Thanks GG!! It works for me!!
