How to move “sensor” lineto the specified position on the track?
I create several sensors of the tracks and wanna them display on the tracks. Here is the problem,
It is shown in the following picture, the red lines (namely, the red lines stand for sensors) are away  from track s . how to control them on the tracks?
Looking forward to your directions ,Any help is great appreciated!
Re: How to move “sensor” lineto the specified position on the track?
Hello MarkLee,
Sensors are placed visually, based on the track pitch setting. The track pitch setting on your 'road' track objects is 4. The roads are 10 meters wide but it does not look that way because you have the setting transfer length turned off.
I think these settings should help you achieve what you want.
Best regards,
Nick Peeters
Consultant
cards PLM Solutions
Nick Peeters
Simulation Consultant
www.cardsplmsolutions.com
Hi,NickPeeters!
     Thanks for  your advice,its great helpful,I work it out.
