How to read in values from txt file
Hi Community
I am new to Tecnomatix Plant Simulation (TPS). I am using TPS 11.2.1.
I have the following problem or question:
I created an inventory control model like seen in the image:
I want to know how to read in values for ReorderPoint and ReorderQuantity by using the method ReadFile and the FileInterface.
Currently the only code in the ReadFile method is:
is
do
	InitValuesForModel.open;
--Need code here :-)
InitValuesForModel.close; end;
I am open to any suggestions. The text file InitValuesForModel.txt currently contains: 10000;20000;
where 10000 is the ReorderPoint value and 20000 the ReorderQuantity value which needs to be assigned (canceling out the old values).
The WriteFile method will be required to write to the file ExitValuesForModel.txt in the following format:
10000;20000;<ServiceLevelValue>
Attached is my model.
Any help would be appreciated.
8 REPLIES 8
Re: How to read in values from txt file
Hello Hopla,
the easiest solution is to use a Table object and the method 'readFile' of the table.
You can configure the table so that the ';' is a column seperator. This way you will get two columns with the data from your text file.
Ralf
Ralf
Thank you for the quick reply Ralf!
Ok so this is the coding i have for the ReadFile method:
is
	i:integer; count:integer;
	Value:string;
do
	FileInterface.open;
	i:=1;
	count:=1;
	while not FileInterface.eof loop
		Value:= FileInterface.readLn;
		ImportedValues[1,1]:=Value;
	end;
	FileInterface.close;
end;
 How do i code it to split values at ";" into different columns?
Just set the column seperator of the list to semicolon:
Ralf
It is set to semicolon and still prints the values in same cell:
Isn't it something to do with the codeof the method?
is
	Value:string;
do
	FileInterface.open;
	i:=1;
	count:=1;
	end;
end;
 Thanx for all the help so far!
You should just use the following code:
ImportedValues.readFile("Name of your file");
Ralf
Ralf
Ok so this is what i used:
is
	Value:string;
do
	--Read in values from textfile
	FileInterface.open;
		ImportedValues.readFile("InitValuesForModel.txt");
end;
 Then i recieve the error:
Permission denied?
Just remove the lines FileInterface.open and FileInterface.close.
The permission is denied because the file is already opened in the FileInterface object.
If you use the readFile method of the table you don't need the FileInterface object at all.
Ralf
Ralf Thanx a million for your help!!!
