How to refer to a list type attribute of an unknown object on the sketch from a method?
Dear Community!
I have several object on my Plant Sim sketch, which all have a list type attribute with name 'Componentfailures'.
What i would like to do is calling these lists of each objects from a  method, and fill them up with some values.
What i've already tried, is represented in the attached picture. About this situation i suspect the problem is, the attribute is a list type, not an object.
Does anyone know what is the problem with this program section exactly, or does anyone know another solution for referring on each attribute one-by-one, and fill them up with the required values?
Thanks!
Re: How to refer to a list type attribute of an unknown object on the sketch from a method?
Hello Pirker,
the path to the list consists of an object path, dot and the name of the list attribute:
var str:string := ".Models.PM.SP3"
var comp_fails:list[time] := str_to_obj(str).Componentsfailures
Peter
Dear Peter!
Thank you for your answer, actually from this point of view it looks totally obvious Smiley Happy .
Best regards,
pirker
