How to restrict MU's?
In my model i want not more then 14 MU's can accumulate between OP10 to OP90. so how can i do it.
Please help
9 REPLIES 9
Re: How to restrict MU's?
Hi Piyush,
define an entrance control of OP_10 and a rear triggered exit control of OP_90.
A variable object of datatype integer (with init value = 0) counts the number of MUs between the mentioned stations.
If the variable is greater than 14 the entrance of OP_10 is locked:
 if ? = OP_10 then
Variable := Variable + 1
else
Variable := Variable - 1
end;
OP_10.EntranceLocked := Variable > 14;
Please do not forget a reset method, which opens the entrance of OP_10.
Peter
Thank you so much Peter. Actually i am beginner at this, i got the logic you wrote but unable to get the reset method. So please help me on that.
The program of the reset method is
is
do
OP_10.EntranceLocked := false;
end;
The reason is that a second simulation will not run if the entrance of the first station OP_10 is locked.
Thanks a lot Peter
Hello Peter,
I am beginner at plant sim. I am trying to built a model in plant sim.
I am bulding a bank model in which customer enters the bank in different number in different time.
eg.
10am -11am -5
11am-12pm - 9
12pm -1 pm - 15
1pm - 2 pm -break
2pm - 3pm -12
3pm - 4pm -15
4pm - 5pm- 10
so how can i get it through source.
Please help
have look at the attached model
Thank you so much
I need one more help.
if i want to run it for a month
how would i do
one way is to wrap it up in another loop (for 30 days s.b.)
is
	L,T :object;
	i,j,m :integer;
	s,e,r :real;
	c:integer;
	Ti :time;
do
	L:=tab1;
	T:=tab2;
	L.delete;
	for m:=1 to 30 loop  -- month loop
		for i:=1 to T.ydim loop -- day loop
			s:= 86400*m+3600*T["start",i];
			e:= 86400*m+3600*T["end",i];
			c:=T["count",i];
			for j:=1 to c loop -- hour loop
				TI:=round(z_gleich(1,s,e),0);
				print time_to_str(ti,true);
				L[1,l.ydim+1]:=TI;
				L[2,l.ydim]:=.BEs.Fördergut;
				L[3,l.ydim]:=1;
			next;
		next;
	next;
	L.sort(1,"up");
end;
c:=T["count",i];
L[1,l.ydim+1]:=TI;
L[3,l.ydim]:=1;
next;
next;
next;
L.sort(1,"up");
Can you please explain me the code...
As i am new to it
