How to run strategy in the center of converter, (not by the front)
Hello. When MU goes on to converter I need stop the MU on its center. After that I want to "run" the method, which can move the MU.
By default way, the strategy method of the converter is "run" by the front of the MU before converter.
Is there any way how to solve it? Or if you have a different solutin, I would like to know it.
Thank you
Re: How to run strategy in the center of converter, (not by the front)
Hi Libor,
At this moment there is no solution for the Converter object itself. The behavior you mention is indeed correct; this enhancement is something we have also asked for.
How to proceed depends on the specific case. If it is not a bottleneck situation, I would stick to the existing functionality and accept there is a deviation from reality.
However, if it is time critical and you need it to behave accurate to the second (which I doubt), you could create your own version consisting of several SingleProcs. Use the variable ConveyingDirection to make sure that the orientation of the MUs remains correct.
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
Ok, thank you for your answer Nomden.
