How to setup camera to record some video for 3D view?
How to record a nice video (3D view) to see material flow from first till last station.
1. How to attach camera and record some videos on each object.
2. How to generate fly over path camera to record video of the whole plant. (Plant tour, 3D view)
Re: How to setup camera to record some video for 3D view?
Hello @Tee
You could use the Record tool inside the 3D environment:
You could define the best settings for your project:
After that just click on the record button. To attach the camera in a object, right click on the object:
Sometimes you want to attach the camera in a specific MU, so, make sure you have the Select Children option activated:
And then:
[Result]
To create the path, click in the Edit 3D Properties button without selecting any object:
After this, go to the Camera Animation tab, click on Add button, set a name, and start creating your path using the camera view or the coordinates.
Take a look at the Help under 3D Viewer Reference Help, there are more detailed information.
Best Regards,
Paulo Araujo
