How to stop simulation when last entity leaves the drain
Ive been working on a simulation, and need to now the total time it takes a certain amount of entities to go through the system. So far the simulation has stopped automaticly when the last entity goes to the drain, but after adding a shiftcalendar, the simulation continiues forever.
Is there an easy way to prevent this?
Re: How to stop simulation when last entity leaves the drain
Hello Christian,
You could check the number of MUs in your model (e.g. Frame.numMU). If none is left, you can stop the EventController (EventController.stop). The Drain may be a good place to do this check.
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
Thank you very much
