How to stopped the line if numMU in other line is greater or equal
I want to ask how to create a control to line that will stoped and start by numMU in a other line. I my case I want to stoped Line, Line1, Line 2 if numMu in Line8 is greater or equal 20 and when numMU in Line8 is smaller then 20 then Line, Line1, Line 2 worked normal.
Thanks in advance for your help!
4 REPLIES 4
Re: How to stopped the line if numMU in other line is greater or equal
this is a typical task for a observer control
--> Tools  - Edit Observers
select the attribute numMu and assign a method
this method now will be called after each change of numMU - so this is the right place to program your logic
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
I tryed to created a method, but i am new on tecnomatix. I wrote this but it is wrong I supposed.
try these 2 methods:
init method
	line.exitlocked:=false
	line1.exitLocked:=false
	line2.exitLocked:=false
observer method for line8.numMU
--param attribute: string, oldValue, newValue: integer
--param attribute: string, oldValue: integer
param newValue: integer
if newValue >= 20  then
	line.exitlocked:=true
	line1.exitLocked:=true
	line2.exitLocked:=true
	print newValue, " OFF"
else
	print newValue, " ON"
	end
Many thanks it worked.
