How to use a same random stream in two lines?
I duplicated a line in my model and run the simulation and found that the throughput result was different even through these two lines are exactly the same. I think the reason is that these two lines may use different random stream in failure. But how can I make these two lines comparable? In this case, they should give me a same result.
Re: How to use a same random stream in two lines?
Have a look at the object attribute "Randomseed"
