I need help to study plant simulation.
Hi, I am a college student studying plant simulation.
I am currently using the student license plant simulation v13. However, our university uses v11 and v12.
So I want to know how to downgrade the plant simulation to the previous version.
If I can not downgrade, I would like to know how to use simtalk 1.0 instead of simtalk 2.0.
Thanks for reading! I really need your help.
Re: I need help to study plant simulation.
Steffen_B 1st Gear
1st Gear
I guess, there is no way to downgrade your Plant Simulation, but you can switch between old and new SimTalk syntax.
If you have open a method select Tools --> deactivate New Syntax.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
  1. You cannot downgrade your version (if you only have a student license).
  2. To use SimTalk 1.0 instead of 2.0, open your Method class and go to the "Tools" ribbon. There you find a switch called "New Syntax" - if that is pressed, the method (and with that every newly inserted method that derives from it) uses SimTalk 2.0, otherwise 1.0.
Thanks to you, I solved the problem.
