I need urgent help with Assembly
Hi All,
I am quite fresh here, so sorry if there appeared similar topic (but I've searched before typing this message)...
Wee, I've attached my model and the case is, that I have problem concerning Assembly "nalewanie".
I've tried to attach an assembly table but then appears an error (I want my product to consist of following MUs: mascara_SA= FI_masa + mascara_komponent).
Can anyone tell me what am I doing wrong?
For the time being, I've changed Assembly table to : None just to check if the whole model will be working properly.
The same problem appears on stations zakrecanie_labelling and sleeving.
Thanks in advance for help!
Re: I need urgent help with Assembly
Hello katarzynazmuda,
In the assembly-list is entered "pred" as interger or the names of BE.
The main part is not entered in the assembly list.
Model is attached
Nadin
