Icon Animation Compromising Processing Performance
Builder
Builder
is there some way so hide or unable all the icons (singleprocs, lines, etc...) to run the simulation?
Icon Change, Icon Rotation and other Icon animations compromises a lot the processing performance!!!!
Re: Icon Animation Compromising Processing Performance
try fast foreward simulation (the two blue arrows at the eventcontroller); you can switch off the simulation in the home tab (MUs,Icons).
You can also try to close the frame while running the experiment...
The icons of singleproc, line and so on, you cannot switch of, only the MU and icon-animation.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
