Import Attributes in TableFile with import
I have created a Delivery Table (TableFile), I am importing the Data with the import functionnality from a Excel file, it's working well.
This table has a "Attributes" column from type Table. I would like to import Attributes from my Excel file like Type. Is that possible or should I import the Attributes programmatically ?
Re: Import Attributes in TableFile with import
Hi Regis,
I think that's impossible. Uses an xml file and the method readXMLFile.
Try the attached file.
Peter
