Importing Excel File
Siemens Creator
    Hello all,
                I am trying to import the attached Excel file into a Plant Simulation TableFile object via Import command.
                This still processing for long time but did not import, do you know How to do it?
Renato Lima
Re: Importing Excel File
Hello Renato,
the problem is that the Excel COM interface is terribly slow and your file is very big (35MB).
You can try to load the data using ODBC:
odbc.DriverConnect("DSN=Excel Files;FIRSTROWHASNAMES=1;DBQ=C:\test.xlsx;");
odbc.sql(TableFile, "select * from [sheet1$]");
odbc.logout;
This should be faster.
Ralf
Siemens Creator
  Hello Ralf,
      I have tried to implement your suggestion but I faced some systems issue, during this time my colleague told me try to import as .txt and wow, .txt imported very fast.
      Thank you for your help again!!!
Renato Lima
I think the trick here is to select an appropriate format in Excel. The best choice would be text with tab delimiters - I believe, you've used it.
Regards, Vladimir.
