Importing a Process Simulation Model into Plant Simulation directly
Hello all,
I am wondering if it is possible to create a fully fleshed out model of a process within Process Simulation and export the times, CAD models, and simulation and import that data directly into Plant Simulation.
If possible, then you can build out the processes within Process Sim and utilize that data within a bigger simulation of a shop.
Re: Importing a Process Simulation Model into Plant Simulation directly
even it would be possible - the question is:
where and when do you need this kind of  level of detail of a fleshed out process simulate model to design and  optimize a production line / complete Body shop with Plant simulation.
Usually during a quote phase this detailed data is not available.
Simulator,
The reason that I am interested in this topic is so that I can create a demo showing the full Process Sim/Plant Sim integration that can be acheived.
Also, I am just interested in learning more about this integration process.
Thank you!
