Increasing load capacity of transporter
4 REPLIES 4
Re: Increasing load capacity of transporter
@ 1 open the transporter dialog
and select the tab "Attributes"  and /or tab "load Bay"
For details, have  look in the help file (s. pic below)
@2. what error are you talking about ?
Hi!!
Thank you so much for your reply.
Yes, I see that. But since I´m using the trial version, i can´t able to access this option.
@2, For instance, three singleproc (A,B and C) and it has respective buffers (bufferA, bufferB and bufferC) to receive raw material through transporter from other source , and storing the processed part to the respective buffers (like Out_bufferA, Out_bufferB, and Out_bufferC). Here, through transporter we should provide (50 parts - Source) to each singleprocs and should take the processed 50 parts (eg: buffer capacity : 50 and it should take the first finished buffer parts -- FIFO) to the finished Store.
I am looking for a SimTalk Program to learn it.
Thank you so much for you help.
@1 this is NO option, it is mandatory standard !
   Please send the model / screen shot .  I hope I can open it to verify this.
@2 This no simtalk error, what you're describing, but more a description of what
   you expect, the model is supposed to simulate.
Hii!
Thank you so much for your reply and help.
Yes, I started to learn about this software a few days before and looking to learn SimTalk Programming. I have attached my rough model here (please look the plant_1 frame).
Actually I am trying to solve the below questions:
1- the transporter from rack would provide 50 parts of sources to each buffer_A,B and C, and workers start doing their job and put the finished parts in Out_Buffer_A and respectives. the Transporter should take away the finished parts to the rack on left side.
Sorry to disturb you by asking simple questions. I´m trying a learn it.
Thanks a lot for your help.
