Inspection after every 5 jobs
I want to model a scenario wherein worker performs the inspection of once after every 5 jobs. Need help in modeling mentioned scenario.
station - loading
station2 - unload
station 21 - inspcetion
many thanks in advance
Betreff: Inspection after every 5 jobs
Use a global variable. In an exit control You Can increment. If it is 5 you can set an attribute on the mu that it must be inspected. In the exit behaviour you can define which successor should be used.
__________________________________
Have a look in the help before asking.
EDAG-PS: https://www.edag-ps.de/
Re: Inspection after every 5 jobs
see e.g. here
https://community.plm.automation.siemens.com/t5/Plant-Simulation-Forum/Sequence-of-worker/m-p/548197...
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
