Inspection of multiple columns in table
I am fairly new to PlantSim and I encountered several problems while trying to build up a logic.
Logic should be like following: For the "W" stream orders from the SalesOrder table, I wanted to compare Quantity value {SalesOrder table} and Amount Value {StockLevel table} for the corresponding SKU.
And if Quantity < Amount then create MU.Order on the 'Shipment' on a predetermined date, smth like Duedate {SalesOrder} - 7 days.
I tried to code this all in a Method, but it didn't work out. I would like to hear your suggestions.
Thanks in advance.
Kind regards,
Orkhan
Re: Inspection of multiple columns in table
Something like this could work:
SalesOrder table:
column 1 = SKU ID
column 2 = Order quantity
column 3 = # days until shipped
each row is a separate order
StockLevel table:
column 1 = SKU ID
column 2 = Current stock level
coulmn 3 = Pending shipments
each row is a separate SKU
Orders are processed in a method as follows:
is
     i : integer
     stockNum : integer
do
     for i := 1 to SalesOrder.YDim loop
          -- find SKU in stock level table
          StockLevel.setCursor(1,1);
          if StockLevel.find({1,*},SalesOrder[1,i]) then
              -- check if there is sufficient inventory
              stockNum := StockLevel.cursorY;
              if StockLevel[2,stockNum] - StockLevel[3,stockNum] >= SalesOrder[2,i] then
                  -- increment pending shipments
                  StockLevel[3,stockNum] := StockLevel[3,stockNum] + SalesOrder[2,i];
                  -- schedule shipment of order quantity to occur at the appropriate time
                  -- (number of seconds in the future)
                  ref(ShipOrder).methCall((SalesOrder[3,i] * 24 * 3600),SalesOrder[2,i]);
              end;
          end;
     next;
end;
In the method ShipOrder, pending shipments and stock level are updated
(orderQuantity : integer)
is
do
     StockLevel[2,stockNum] := StockLevel[2,stockNum] - orderQuantity;
     StockLevel[3,stockNum] := StockLevel[3,stockNum] - orderQuantity;
end;
Thanks a lot Robert!
