Interface with Line Designer on NX 10
Siemens Creator
Can Plant Simulation interfaces with Line Designer on NX 10 like FactoryCAD?
Should it be possible through Teamcenter?
Re: Interface with Line Designer on NX 10
Siemens Legend Siemens Legend
Siemens Legend
Hello Franz,
Plant Simulation will have an interface to Line Designer to reuse the factory or line design in terms of discrete event simulation. The interface is under consideration right now and we are working on a first prototype.
Techically the data sharing will be done through Teamcenter but there shall be possibility to use a "tiny" Teamcenter configuration, running in the background,  just as a kind of "data server".
Best regards
gepi
Siemens Creator
Thank you, Gepi.
Could you let me know when it will be available roughly?
Franz
