Issue: Simulation of automated Coffee SHOP in 2D
I need some help in creating the coffee shop with a robot picking and placing saucers from stack to  coffee machine.The made coffee is placed on the shuttle, which delivers  the coffee by moving around the dinning area. The Dining area chave 5 places.
The coffee machine have 3 options of coffee and time varies for each.
4 REPLIES 4
Re: Issue: Simulation of automated Coffee SHOP in 2D
Where did you get stuck ?
How to generate a order? and how to make it again say some after 2 minutes, and say for example if my 1st order is three different coffee i can make only one coffee at a time, now for every coffee i need my robot go to milling machine how do i do that?? and i need to get the data as whole that is order and i need to execute the elements of order separately. how to do that ?
you can create the orders with generator + method; for storing the information you can use a tableFile (DataTable).
You can format one column as table and  in this way you can store all positions of one order in one table row.
Have a look at the method z_dEmp, here you can define empirical distributions (e.g. how many positions, what kind of coffee). This you can use to dice first the number of positions (see also z_normal, z_uniform) and then based on a empirical distribution the different coffee types...
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Yeah sure I'll look into that. Thank you so much.
