Issue of unwanted MU blockage on line due to sorter capacity
A basic layout i am using is attached herewith. Total number of parts is 38. When i give the capacity of the sorter as any number less than 38, parts get blocked on the line 1 as shown in the attachment provided herewith. The method code i am using is also attached. A solution to this problem will be greatly helpful. Thanks! (Part 1= red, part 2= orange)
Re: Issue of unwanted MU blockage on line due to sorter capacity
What is the sequence of R1? And why a sorter ?
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Sir, the source will generate MUs based on poisson distribution. I'm using a sorter so that i can create a sequence such that all part 1's are sent first followed by all part 2's ( The reason being setup time will be reduced)
can you post your model?
Steffen Bangsow
web: www.bangsow.eu
look attached an example with a basic set of controls:
- exit strategy for the PickAndPlace for distribute the MUs depend on their predecessor
- exit control of the sorter for waiting for a empty SingleProc
May be you need to wait also in the exit of the line for space in the sorter
Steffen Bangsow
web: www.bangsow.eu
