Label is not displaying
Innovator
Innovator
hi,
There is tecnomatix setup in the VM.
I have added the label for each station. But in the 3D view in VM, the labels do not show up. Only a white box is displayed.
What is the reason for it?
Re: Label is not displaying
The virtual graphics adapters on virtual machines often turn out to be pretty rudimentary.
Depending on the actual virtual machine, the limitations range from a siginificant decrease in performance while rendering a 3D scene (this is practically true for all VMs, at least for the ones I have seen) up to the application not being able to start at all because the virtual graphics adapter crashes on first sight.
Your VM seems to be somewhere in-between: capable of basic rendering but incapable of textures
