License error
Hi
I am facing a error message
Professional license is not available
the desired vendor daemon is down, (-97)
Do you want to use license viewer?
4 REPLIES 4
Re: License error
look for the lmtools (programs - siemens - siemens plm license server - LMtools) tab start/stop/reread
stop the server
start the server
reread the license file
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Re: License error
Hi Steffen,
Thank you for quick reply.
Facing same issue after doing the following
stop the server, start the server, reread the license file
FlexNet Licensing error:-97,121
Please let me know what needs to be done.
Re: License error
Hi Steffen,
Re: License error
have you read the debug log file? (tab config services), there should be a hint, why the service couldn't be startet
you need to configure your firewall, so that Plant Simulation can communicate with the license server
Steffen Bangsow
web: www.bangsow.eu
