License file isn't working
Tecnomatix Plant Simulation does not accept the license file I got by e-mail.
I am running Version 12 64-bit and conducted the whole installation process as outlined in the license e-mail. I put the .lic extension on the license file and changed the license type at preferences settings to educational, but always receive the same message (Educational license is not available / Can not find license file)
What went wrong?
Thank you advance for your help.
Best regards
Rolf
Re: License file isn't working
I feel possible reasons there:
check your license file content received by mail. is it a floating one or a nodelocked one? if floating one. you need to change hostname ( first line one) to your current host name then using siemens license management tool to drive this license service up; also Siemens plm using 28000 as TCP port number by default;
if nodelocked one, just double check your HostID/CompositerID  in license file is matching current PC's hostid ( by using siemens checking tool together with software).
Wish you get thru it.
