Line/Arc Dialog Box
Hi all,
I am creating a logistics model and for that I have a copy of the TwoLaneTrack into my class library. What I want to do is whenever I drag and drop it into the frame, open the line/arc dialog box.
Is it possible to open that window via SimTalk? I couldn't find it on the help files.
Re: Line/Arc Dialog Box
Add the copy to a toolbar and insert its instances by clicking on the toolbar item and then in the frame. That way, the dialog will open automatically.
