Line Break in string
hi,
how can i add a Line Break to a string ? So for eg. (Pseudocode)
-- Method
is
do
  ref(Method1).program := ref(Method1).program + "\n-- test";
end;
and then the Method1 code should be
-- Method1
is
do
end;
-- test
1 REPLY
Re: Line Break in string
ref(Method1).program := to_str(ref(Method1).program, chr(10), "-- test");
