Line efficiency
Hi Folks,
I have a question to ask. Is there any way to get the line efficiency of the simulation model?? Or we still need to calculate it by using the available formula.
Really appreciate your feeback though.
Thank you
Saiful Akmal Razali
Bachelor of of Mechatronics Engineering (UMP- Karlsruhe University of Applied Sciences, Germany)
Faculty of Manufacturing Engineering
University of Malaysia Pahang (UMP)
26600, Pekan, Pahang
MALAYSIA
Re: Line efficiency
Can you be more clear about what you mean? Do you mean the Line object, or a production line in general?
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
Re: Line efficiency
Hello Gert,
What I meant is the production line in general. I have an automotive production layout that consist of 3 lines which are (Trim, Chassis and Final) and I need to know what is the overall line efficiency for each one of them so that I can compare between the manual calculation with the simulation result.
Thanks for your attention.
Thank you
Saiful Akmal Razali
MALAYSIA
Re: Line efficiency
just place a singleproc with the line cycletime at the end of the productionline
and read the statworkingportion attribute which equals the line efficiency
Re: Line efficiency
From the Drain you can check the average exit interval (Drain>Type Statistics) and how MUs have spent their time before the entered the Drain.
If you connect every line to its own Drain, you can evaluate each of thm individually.
Gert Nomden
Re: Line efficiency
Dear Gert,
Thanks for the feedback.
Really appreciate that.
Thank you
Saiful Akmal Razali
MALAYSIA
