Loading a transporter Partially!!
Hello community,
I have a situation where the transporter is loaded with 30 parts(10 part A, 10 Part b, 10 Part C). The transporter moves on the track and unload all the part A at station A, all the part B at destination B and all the part C at destination C.
My problem is how i can unload part A only at destination A and not part B and part C. How can i find out all the relevant parts to be unloaded at the correct station?
3 REPLIES 3
Re: Loading a transporter Partially!!
If a dismantle station is ok, you can set the successors of "A" , "B", "C" in the dismantlelist.
Or of course you can DiY by scanning the contentsList of the transporter and moving "A" , "B" , "C"
accordingly to their destinations.
Thank you simulator. I think dismantle station might not be suitable in my suitation. Please look in the pic. Could you please elaborate a bit how can i achieve this by scanning the content list and DiY. I am using Plant Simulation 14 where i can see that a new z dimension is being added in the loading of the transporter.
Thanks in advance!!
I think you could solve this by using the TransferStation found in the TransferStation library. I have attached a model  based on the case you described where that worked for me. The transporter here is loading the parts only along the x and y axes, as the TransferStation does not support parts that are loaded along the z axis yet.
Kind regards,
Igor
Kind regards,
Igor
