Locking Position in 2D/3D
Is there any way currently to lock the position of an object in 2D or 3D so that the user cannot move that object around a frame? The reasoning behind this is to prevent accidental movement of these objects.
I cannot find an attribute or menu button to solve this issue.
Thank you ahead of time!
-Patrick
Re: Locking Position in 2D/3D
Hello Delaney,
Please use the lock structure command available in the General tab.
When you enable it, it prevents unintentional changes i.e., inserting, deleting, and changing of objects as well as changing the position of objects.
Thanks & Best Regards,
Abhilash Sridhar
Mercedes Benz R&D India, Daimler AG
