LockoutZone for blocked SingleProcs
Hi everyone,
I found the item LockoutZone. That's exactly what I search for but unfortunately it only works if a failure occurs.
So my question is:
Is there an item like this to stop the line also if one singleproc is blocked?
best regards,
IceTea
Re: LockoutZone for blocked SingleProcs
The other possible object is the Cycle object. You find it with the MaterialFlow objects.
Gert Nomden
cardsplmsolutions.com
Hello Nomden,
Thanks for your reply. Thats the one I was searching for.
The only Problem is that it just works for SingleProcs or simular stations but not for lines...
Do you know any solution for this?
Best regards,
IceTea
In that case I can think of one alternative yet simple solution. On the attributes tab of the objects you can define a Cycle time. If you define a constant and give it the same value for every object, then it works in the same way.
If this is too simplistic, then you would need to create some logic of your own.
Gert Nomden
