MU Display Panel
Hi Community,
All my MU's in my system are created with different weights. This is stored as a user created attribute.
Is there a way (in 2D) to display the weight of each MU as a Display Panel above/below the MU while it is moving through the system?
Re: MU Display Panel
No, but in a Frame you can choose to show Object Labels. Hence, put the weight into the MU label and show it.
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
Hello Armand,
         There is no "Display Panel" item for MU objects, and the label is a best way.
Thank you very much.
