MU.create
I have an issue with the create-method on an MU. When setting the CopyStatistics parameter to true the statistics for calculating lead time is not copied. Is this intended behaviour?
Re: MU.create
It seems that this is a bug. I think this behavior change was introduced recently by mistake.
We will look into it and fix the problem.
Re: MU.create
Thanks!
