MUs Animation
Hello everyone,
I have a problem about animating an entity in a transporter and animating the transporter.
What I need to do is that when the transporter reaches the curve of a line, to keep the position it had in the line and when the curve finishes, to take the same position it had before.
About the entity, I need it to rotate 90 degrees when it reaches the curve of the line and when the curve finishes, to keep the same position it had before it entered into the curve.
*I wanted to attach the file but the page won´t let me, if someone needs the file I´ll share it by sending an e-mail.
Thanks in advance
Marco Rodríguez Motilla
8 REPLIES 8
Re: MUs Animation
you can deactivate "rotate movables" in the tab curve of the line or you try the AngularConverter
to rotate the MU you can use the method turnIcon
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Re: MUs Animation
@ sharing /uploading  *.spp files
zip the *.spp file before attaching for upload
Re: MUs Animation
Thanks, but it didn´t work. I already could attach the file. I hope you could help me.
Re: MUs Animation
the AngularConverter works well in 2D and 3D
Steffen Bangsow
web: www.bangsow.eu
Re: MUs Animation
Thank you, now I just need to rotate the entities 90° when they reach the angular converters.
Re: MUs Animation
you need different approaches for 2D and 3D
- 2d: turnIcon(90) e.g. as exit control rear in line:
for var i:=1 to @.numMU loop
   @.mu(i).turnIcon(90) --2D
   @.mu(i)._3D.rotation:=makeArray(90,0,0,1)--3D
next
Steffen Bangsow
web: www.bangsow.eu
Re: MUs Animation
Thank you Steffen, I already could make my MUs rotate, the problem now is that it stops at the end of the line instead of continuing in the angular converter.
Re: MUs Animation
use the exit control rear and not front (if you use the exit control with activated checkbox front, you need to move the MU at the end of the method: @.move)
Steffen Bangsow
web: www.bangsow.eu
