MUs Container- problem
When i Use MUs then the line sort the Atributes.
But when i use Pallets it dont work.
Why?
Thank you for your help
Re: MUs Container- problem
Hi Necmi,
the Line Förderstrecke4 evaluates the Pallets and not its contents.
My solution: I equipped the class .BEs.Fördermittel1 with boolean attributs rot, blau and grün (german words for red, blue and green).
Set all values in the class false.
In a sensor control of Förderstrecke4 I set:
 if @.cont.getAttrNo("Blau") > 0 then
@.blau := true;
end;
The same for "rot" and "grün".
Peter
