Make an action at a specific time based on a ShiftCalendar
In my model after the production all my entities are loaded in a store.
All the entities in that store are loaded in a truck at 4 PM each open day (based on a ShiftCalendar), I don't need to take care at the loading time.
I tried to do that with a Generator and a Method who moves all entities from this store to the truck (Drain), it works but without taking care of a ShiftCalendar (should only move the entities to the drain on open days).
Is there a better way/object to achieve that use case with a ShiftCalendar ?
Thank's for your help, regards
3 REPLIES 3
Re: Make an action at a specific time based on a ShiftCalendar
maybe pulling the parts through a Source (with set ShiftCalendar)
and AssemblyStation is more like it.
you need just to check, if the shiftCalendar is unplanned or not before you move the parts
if shiftCalendar.unplanned=false then
--load your parts
end
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thanks, I have taken the method from Steffen with a Generator.
I have attached the shipment frame I've made.
